1 - 4 of 4 Posts
Hello all. I'm looking for suggestions on a new base system. I am in need of a different case and I'd rather put together a new base system and move my GPUs and M.2 drives. Case will be an X5, GPUs are SLI Waterforce AIO 1080ti. Also moving over two Samsung 950 EVO pros.
I am happy with my current setup, with exception for the case and fan setup. There's just not enough real estate in this 570x for all the AIO rads I have. I will mostly use this for gaming, with some 4k video and image editing.
Budget is sub $1200.
I prefer Intel, but am open to AMD if the change is for the better.
I'd prefer to have enough Pcie lanes for max performance, as I do run benchmarks from time to time.
Stability and reliability is also vert important. Even with my 7700k at 5.1ghz and my GPUs at 1987mhz @.993, I never have issues.
9 Cans of Ravioli
You need more than 16GB?
Could get an i9 7900X and an MSI Raider for $1100 and reuse your current RAM. Drop down to an i7 7820X if you need to fit more RAM in your budget.
There aren't many upgrade paths for a 5.1Ghz 7700K other than MOAR KOARS.
16gb has always been enough. I'd rather not sidegrade. If I should wait a bit, I can. I've been digging around and don't see anything that is really worth sticking it out for.
9 Cans of Ravioli
Single core performance would be the same assuming you can also clock the 7900X/7820X to 5.1Ghz, so if it's just for gaming, I'd just stick with what you have. Very few games take advantage of more than 4 cores.
1 - 4 of 4 Posts
