1 - 5 of 5 Posts
Should upping my CPU-NB voltage directly effect my NB temperatures?
I would think so but i am running 1.5V and there are no big temp increases at all.....
Discussion Starter #5
Originally Posted by Mastiffman
No, increasing the CPU-NB Voltage will increase the CPU temp. Increasing the NB CHipset voltage will increase the NB Chipset temps...
Mmmm that is some of what i have been hearing
CPU temps haven't really increased though
So is it the general consensus that my CPU blows
Originally Posted by youra6
1.5v for CPU/NB is fine, you can set it as high as the cpu voltage which is 1.55v
That only applies if you can cool that much voltage...i already new the suggested voltage limitation
1 - 5 of 5 Posts
