1.325v is stock
So right now you are at
1.7v according to what stock is.
That's way to high though. And I think something is up.
Or you are just saying it wrong. What are you overclocking with?
Either way, max CPU-NB voltage is 1.55v unless you have a a CPU-NV VDD option in your BOIS or one like it, which allows you to go over the AMD spec for LN2/Phase/DICE runs.
