1 - 14 of 14 Posts
look at the letters in red and please tell me what it means......
Intel Pentium 4 3.2E Prescott 800MHz FSB Socket 478 Processor Model
64 bit Support: No
Cooling Device: Heatsink and Fan
Hyper-Threading Support: Yes
L1 Cache: 12KB+16KB
L2 Cache: 1MB
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Operating Frequency: 3.2GHz
Process Type: 90 nm
Series: Pentium 4
Voltage: 1.25-1.525V
i see some that say that and some that say 65nm and some that say 0.13 µm
or something
in laymans terms whats this mean and which is better????
i have a P4 2.6 which is 0.13 µm and i can get my hands on a P4 3.2 that says 90nm. should i do it??
that is th physical size of the microchip...90 nanometer i think it is.. is the standard used now, but we are moving into the 65nm chips, they run cooler and use less power to achieve a givin performance level... 65nm seems to be the future size... but yrs down the road we will probably see like 25nm then 10... but i have no proof of that..lol
so whats the 0.13 µm mean? is that better than the 90nm or is 90nm better?
that i dont know honestly,but i think that is physical size aswell, 0.13 micron, and amd uses that one while intel uses the 90nm and 65nm, have you tried to google it and see what it is?
That is 130nm... a little slower process type, the northwood core is based off of .13um. I would choose the 90nm over the .13um, but it's hard to compare the two..
and the .90nm 65nm ect has to do with the process type.. not the actual size of the processor. But yes, you are corret about the temps..
0.13 µm is 130 nanometers. it's larger than 90nm chips, so it takes more power to run them.
in very very simple terms, the smaller the size, the more parts they can pack in there, which gives capabilities for more features, more memory, etc. etc.
That is the last gen processors.130nm then to 90nm now then to 65nm for the next generation.
Yes, I would upgrade to the 3.2 from your 2.6. You will see a large preformance jump and will probably OC better than your 2.6. 4GHz will be in range with that processor if you keep the temps down.
ok well i was wrong and i stand corrected... thanks guys...
im still tryin to learn all this stuff myself..
hopefully temps wont be a problem, i have 7 case fans, and the zalman cpu cooler.......i may have to get this processor hmmmmm
Yea, I do recommend you get a new processor, everything in your rig looks sweet.. Taeric, a moderator has a very similar setup as you (except with a 3.2E we were talking about, and a xp-120) and he reached ~3.9Ghz stable. You should hit similar results, though you may need a devider with that memory.
Discussion Starter · #12 ·
what do you mean a devider for my memory?
I remember when......
Well, they've already unveiled the 45nm (not for purchase, but they have made them for testing)
ya well ima hop in my time machin and go grab a pentium 7, 5nm processor!!! haha benchmarking w/ 20Ghz
1 - 14 of 14 Posts
