1 - 14 of 14 Posts
Ok so i got my new mobo, cpu and video card today. I am just wondering what stepping i got on my CPU. Its a Opteron 148 and the numbers are as follows.<br />
<br />
OSA148DAA5BN<br />
CAB2E 0604CPMW
Edited for clarity:<br />
<br />
CAB2E is the Core. 0604 is the week. CPMW is the (sub) Stepping. All 3 of these criteria determine the overall Stepping of the CPU.
It seems like a great stepping!<br />
<a href="http://www.xtremesystems.org/forums/showpost.php?p=1417556&postcount=4977" target="_blank">http://www.xtremesystems.org/forums/...postcount=4977</a>
<tr>
<div>
Originally Posted by <strong>LifIsPeachy02</strong>
</div>
<div style="font-style:italic">Is that a good stepping? About what are these overclocking too?</div>
</td>
</tr>
</table>
</div> Look here also for stepping and OC results...<a href="http://www.amdgeeks.net/insertstepping" target="_blank">AMDGeeks.net - your amd overclock source</a>
Reactions: LifIsPeachy02
Discussion Starter #7
<tr>
<div>
Originally Posted by <strong>Sideburns</strong>
</div>
<div style="font-style:italic">the second line is the stepping.<br />
<br />
The last line is your S/N. Take that outta your post.</div>
</td>
</tr>
</table>
</div>Thanks. Fixed.
Discussion Starter #8
I have AS5. Should i put that on the CPU. I Know its better than the stock stuff but do i need to scrape off the stuff thats already on the stock heatsink?
Yes, you should clean the old stuff off completely before applying the AS5. Be sure to use the proper amount as well, a BB sized dot in the middle will be plenty to cover the whole CPU once the HSF is tightened down.
Remove the old stuff with out scratching or gouging the HS and clean with Alcohol, preferably 90% and a lint free cloth.<br />
<br />
Oh, and CAB2E are usually a good stepping <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Retired
<tr>
<div>
</div>
<div style="font-style:italic">I have AS5. Should i put that on the CPU. I Know its better than the stock stuff but do i need to scrape off the stuff thats already on the stock heatsink?</div>
</td>
</tr>
</table>
</div>Yes, you will need to remove the TIF that is currently on the HSF should you wish to use your AS5. You can do this with some hydrogen peroxide or isoporply achohol.<br />
<br />
EDIT: Wow, im slow... beat by the Duke and RyGuy.
CAB2E are a VERY good stepping. They're known to hit up to 3.1 GHz!
<tr>
<div>
Originally Posted by <strong>tubnotub1</strong>
</div>
<div style="font-style:italic">Yes, you will need to remove the TIF that is currently on the HSF should you wish to use your AS5. You can do this with some hydrogen peroxide or isoporply achohol.<br />
<br />
EDIT: Wow, im slow... beat by the Duke and RyGuy.</div>
</td>
</tr>
</table>
</div>You may have been slow to the draw on that one but you are GOOD <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 14 of 14 Posts
