1 - 7 of 7 Posts
SOLVED
Hi
I used to use Afterburner to see cpu temperature and usage.
Now i have a new gpu, and i had to reinstall afterburner.
But now i cannot monitor/osd cpu usage and temp.
I've been googling but i read everywhere i need to install hwinfo32/64.
But it worked before with Msi Afterburner alone.
Can someone help me?
it used to look like this (not my pic)
Did you download the latest version? Unwinder just released it on Guru3D
You need to install the Rivatuner Statistics Server which comes with the installer that you download, then you can go into settings and set up OSD etc.
Originally Posted by DF is BUSY View Post
i used to have those options too, but only when I used the beta versions.
i think the stable versions off the msi website don't have those options.
If by 'stable' you mean non-beta versions of AB then yes, they do not have CPU monitoring in the OSD.
But thats because they are outdated by at least a year or so and don't even support the latest gfx cards. If you want to use AB on 7xx or R9 then you need to keep up to date on what Unwinder is doing. As far as I know he does not release unstable builds, surely almost all the 3.0 betas run solid.
1 - 7 of 7 Posts
