1 - 8 of 8 Posts
Layer 8 issue
I need program that i can use to see my CPU temp. I have tried MBM5 but i dont see temperature readings anywhere. What should i use?
Layer 8 issue
which reading shows my CPU temp? (temp 1, temp 2, temp 3, temp, local temp, remote temp)
Originally Posted by .XiLe.
which temp is my CPU? (temp 1, temp 2, temp 3, temp, local temp, remote temp)
what does it say under those temps?
You have an ultra-d, why not use the smarguardian that comes in the mobo cd?
EDIT: In MBM5, the CPU temp is always sensor 1. Since you got a DFI, it is an ITE Super I/O, change sensor 1 to read the diode 1 and see what happens. You can also download the plug-in for sli motherboard, as it is already configured for Ultra D, DR, DR-Expert, and I have successfully implemented it on an nF3 mobo too.
Layer 8 issue
Discussion Starter #6
Thanks! Never knew what smartguardian was..
My CPU temp is 33 C. Is that a good temp?
Is that idle or at load? It is a good number, but it would be nice to know how much work is the system doing when you take that reading.
1 - 8 of 8 Posts
