1 - 20 of 42 Posts
Linux Guru
Originally Posted by Napsterbater
i went into bios, and found that my un oc'd cpu temp was 47*C. is this good?
47C is good for your process, because of the core I would want to keep that one under 50C at all times, the 47C was probably on idle, so the load temp most likely exceeds 50C. I would be looking into a new HS if I were you.
bios temps are too high in reality your probably idling in the low 40C territory not bad. my biod said i was running at 15C when used my probe utility it said 6C and big difference if ya know what i mean
Linux Guru
ya im upgrading so im getting an aero 4 lite. right now my case only has one fan but im upgrading to 7
That HS only has 10-20 CFm on an aluminum HS, it will offer little protection if not do worse than the stock one, I recommend looking at 30+ CFm on an aluminum HS.
Linux Guru
That's ok, the post will help others, also I made a typo you want to find an all copper HS or a aluminum with a Copper core for better heat dissipation.
The oder of heat conductors from worst to best is:
Aluminum
Copper
silver
and I beleive Diamond is the best performance, but not easy to find.
Edit:
The AS5 is a good purchase, it will help a lot.
Linux Guru
look at the reviews no newegg
"Cools well. P4 Northwood 3.2GHz running at 3.8GHz, idles at 41C. "
I don't beleive it with the stats on that HS, they may be getting that with the box getting cool air from outside.
Linux Guru
btw, i have one case fan in the back. should it be intake or exhaust?
In the Front, out the Back.
It is always recommended to mount twin sets, always have the same amount being pushed in as you have being pulled out.
Linux Guru
yes my new case will have one front, one side, one bottom, and 3 back
mount the back to be outlets, and all others to be inlets, use the same fans to keep the pressure balanced.
Linux Guru
yup, will this lower my cpu temp?
The better ventillation will help to lower the temps, but you will not need to have the full 6 fans running that may be overkill, try two on the back, 1 on the front, and 1 on the side.
Linux Guru
o lol i kno why my temp was so high, ive had folding @ home running taking up 100% of my processor with also explorer and aim running
Those are your temps on load, the BIOS reading is temps on idle.
1 - 20 of 42 Posts
