Hello,
Just got my H80i installed and have started to tune my rig.
Before I got my H80i, I just tested a bit with my stock cooler.
With my stock cooler, I got a stable 4.3GHz @ 1,250v but with to high temperatures. Reached 100 degrees running AIDA64 and the cpu throttled down.
What I can't understand now is that after I installed the H80i, I can't even run the cpu at 4.0GHz @ 1,250v without windows freezing, while running AIDA64. The temperature is never over 70 degrees before it freezes.
Why is this? Can the CPU be more unstable just because I changed the cooler? I'm getting lower temps after I installed the H80i, so I'm guessing that there is good contact between the cooler and CPU.
Any thoughts?
Any thoughts?
