Those are stock.
Right. But this will still give you a reasonable idea of the difference. You can select different models from the drop-down menu, ie the 1075t instead of the 1055t and compare the individual benchmarks with one another.
Glad you were able to make use of the tool!Originally Posted by L4dd
This would be a better comparison, but any of the Vishera line could be overclocked:
http://www.anandtech.com/bench/Product/203?vs=698
~4.5GHz is a realistic expectation for this processor, but again your mileage may vary depending on the board, type of cooling, etc.
4.7-5.3ghz from what I have seen, but there is no guarantee on it. Because all cpu/mobo oc different.
basically overall
