1 - 6 of 6 Posts
Need help, i got a old processor a pentium d 2.66ghz still working fine but looking forward for a new build and was wondering wad cpu and mobo to get? Any replies or recommendation is welcome
Btw i live in Singapore, budget should be around 400sgd.
Where will you be buying from?
Also you'll need ram aswell unless you have some DDR3 already as most new builds will use it,.
You could upgrade to the same set up as mine for under 400sgd
Thats :
Phenom II x2 555 B.E 3.2GHz
Asus M4A88T-M
G.Skill Ripjaw 1333MHz DDR3 4GB
Plus there's a good chance you can do like I done and unlock it to a quad core.Its not guaranteed but its a bonus if it does.
1 - 6 of 6 Posts
