1 - 17 of 17 Posts
Questionnaire galore!
Hey guys can i somehow make a mod or update for my BIOS to change the CPU Voltage?
Not new to Overclock.net
Doesn't this BIOS support overclocking?
Depending on the board, your current BIOS might already have the options, but in a hidden "advanced" screen. For example, my old Gigabyte 790GX board had an Award BIOS on it, in which voltage settings and such were hidden. But you could press something like ALT-F11 or something silly which would "unlock" those options.
Originally Posted by gillbot View Post
what motherboard, that might help
The motherboard in question is the MSI 945GCM5-F V2, just as it says in his sig rig.
Never assume, always verify.
Yeah, but see I know. And time will tell.
Besides, his rig's name is "Overclocking in Progress".
and my rig's name is "cheap", how "cheap" do you think an LGA1366 rig really is?
Never assume grasshopper.
Ok. Sure. But again: I just know. You'll see.
Discussion Starter · #12 ·
My MB can support the OC'ing but only the Memory and PCI-E Voltage Memory Timings and FSB Speeds
Discussion Starter · #13 ·
Discussion Starter · #14 ·
Sorry but it's a MSI 945GCM5-F V2 (FSB 1333)
Discussion Starter · #15 ·
Originally Posted by [email protected] View Post
hmm maybe try Shift+F2 or Alt+F3 also. not sure though
some mods hmm but it doesnt say anything about a change in the frequency/voltage control menu. have you tried the latest official bios?
http://www.msi.com/index.php?func=pr...1&prod_no=1598
maybe through software or something?
Yes i did try the latest official BIOS for my MB 17.A Or otherwise know as 17.10
CPU voltage is the maximum amount of volts that is being routed to your computer's processor at any one time. Increasing CPU voltage can enable your laptop to run at higher speeds, but at the cost of shortening its useful life. CPU voltage is adjusted by using the BIOS settings for your pc, but be cautious with your increases lest you inadvertently damage your system.
Discussion Starter · #17 ·
I know those info
1 - 17 of 17 Posts
