1 - 9 of 9 Posts
I'm used to an AMD overclock (only on a NF4 board) where there is only one CPU voltage. On this 680I mobo, there are 2 different voltages for the CPU. There is the CPU one and the CPU FSB one, which one is important to maintainning a stable clock? We got the CPU FSB is now upped to 1.3V instead of 1.2V and I'm wondering if that is fine? We are also at 1.2205V or something like that on the other side.... I'm running blind here
Any help would be great
BTW, we are trying to get a Q6600 to 3.0GHz.....
just worry about the CPU core, the cpu fsb is usually fine at default.
You should get 3.0 on that fairly easy with proper cooling.
Originally Posted by ghozt302
just worry about the CPU core, the cpu fsb is usually fine at 1.3
usually? If we set it back down to 1.2V, wouldn't make a huge difference? Thanks for the post man
Not new to Overclock.net
The CPU Core is the main one to worry about. For 3.0GHz, you may only need between 1.30V and 1.40V. with maybe a 1.20-1.30V FSB voltage. Always avoid "Auto" if you can.
Oh, and be sure to disable the following to help get the most out of the overclock:
  • Spread Spectrum
  • Intel Speedstep
  • CPU Thermal Control
  • C1E Enhanced Halt State
That's about as much as I know. If you have troubles overclocking this, then be sure to flash to the latest BIOS.
NP, I changed it to default btw..
Let us know how it works out and give us benches!!
  • Spread Spectrum
  • Intel Speedstep
And Yes these are a must!
You normally don't need to increase FSB voltage until passing or nearing 400 fsb, this depends on the chip and board. At 333 fsb, stock fsb voltage should be fine. As for the vcore, 1.22v is low for a Q6600. If the vid is 1.22v and it defaults at that, you probably have a good chip on your hands. You still might need a little bump to hit 3.0ghz, but many can do 3.0ghz at stock vcore.
One more thing and I'm not too sure about it. I remember reading that some boards were really bad with quads, I think that it was the 680's but I"m not sure.
You're right about the 680i's which is why I recommended a BIOS flash if the overclocking proves to be too difficult or impossible.
Well VID isn't everything (3.2 GHZ with 1.22v here with a VID of 1.275) but it's generally good to have a lower one. 3.0 should be extremely easy to achieve. just put it at 333x9, adjust ram to desired speed, and set the volts to about 1.30 (windows) and then work your way down.
1 - 9 of 9 Posts
