1 - 3 of 3 Posts
Hey all - in the middle of overclocking a new system with the specs below.<br />
<br />
As you'll see I have a dual-core AMD 64 3800+... I'm checking for my Max FSB first and lowered my CPU multiplier to 5x... Bios and reboot flashscreen show it correctly, but CPU-Z shows my multiplier as remaining the stock 10x... Anyone know why?<br />
<br />
I'm guessing the fact that it's a dual-core is freaking it out a bit - I dunno...<br />
<br />
Anyway - was just wondering.. thanks for any info
AFAIK the VSTA edition doesn't support multiplier changes. Someone tell me this is right <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Oh yeah, BTW. It could also be because of that you have all 4 RAM Slots filled up. Try with only 2 and see if it helps (Note, let them sit in dual channel, so in slot 0 and 2, not slot 1 and 2)
There may be some thing wrong, but that may be because we have different boards, tyr the multi at 7 that usually works
1 - 3 of 3 Posts
