1 - 20 of 335 Posts
Network Enthusiast
Originally Posted by Kuivamaa View Post
Definitely a high overclock in there. Question is ,if it was on air,water or LN2.
Wow, this is the 1700x.
Wow.
This could be LN2, but still.
Wow.
Reactions: BarryBadrinath
Not New to Overclock.net
Wow.
Wow.
Well unless there is heavy binning between the 1700x and 1800x, we should expect very similar scores between the two. All that matters now is frequencies and cooling method.
Network Enthusiast
PC Enthusiast
Based on these results, The 1700x might be a good overclocker.
Unless LN2 was involved
According to this video, a good motherboard might be key.
Overclocking Enthusiast
There were other leaks earlier last week with far more conservative scores on a 1700.
This is my 6850K at 4.6Ghz. For the more rational among you, I think that makes things a littler clearer
Network Enthusiast
Your 3200Mhz CAS12 RAM is no joke either.
Ryzen is more of a beast than we thought?
GG intel. AMD have bested you.
This is 8 core from AMD consuming a lot less power than the 6 core from intel...
Sick!
1700X / 6800K
Platform Power Draw (CPU Full Load) The lower the better.
123w / 126.87w
Platform Power Draw (System Standby) The lower the better.
62.77w / 98.74w
Platform Power Draw (Gaming) The lower the better.
154.66w / 194.2w
Platform Power Draw (Office Work) The lower the better.
81.55w / 113.5w
I am really happy to see AMD having something solid and great.
If Intel doesn't step up, they are sure to lose market share. I'm so tempted to save for AMD build.
Ryzen is definitely no joke, but the result posted in the op is either sub zero, or a suicide run validation, IMO
Network Enthusiast
Perhaps. From what we've seen IPC wise i think this is a 4.6Ghz run.
But Shiftstealth, it beats the 7700k!
Yeah, it isn't that far off of it, and without proper turbo'ing on the 7700k i could see it winning out at 4.6Ghz.
I do not think this needed LN2 to hit 4.6Ghz
Hello. That diagram is in Chinese, I'll translate for you.
3DMark Firestrike Physic score
3DMark11 Physic score
Ludashi 5.15 CPU score
Ludashi 5.15 GPU score
Ludashi 5.15 Memory score
Ludashi 5.15 Disk I/O score
Blender 2.78A (second, lower the better)
7zip 15.05 beta 1min
LuxMark 3.1 CPU Opencl
Fritzchess
Cinebench R15 ST
Cinebench R15 MT
Platform power consumption Full-load (lower the better)
Platform power consumption Idle (lower the better)
Platform power consumption Gaming (lower the better)
Platform power consumption Office-usage (lower the better)
Ashes of the Singularity DX12 - Average FPS
Battlefield 1 Average FPS
Call of Duty 13 Average FPS
Counter Strike Global Offensive Average FPS
Counter Strike Global Offensive Minimum FPS
CrossFire 4.1.8 Average FPS
CrossFire 4.1.8 Minimum FPS
Deus Ex: Mankind Divided Average FPS
Deus Ex: Mankind Divided Minimum FPS
DOOM-VULKAN Average FPS
DOOM-VULKAN Minimum FPS
H1Z1 | King of the Kill Average FPS
H1Z1 | King of the Kill Minimum FPS
Hitman 6 Average FPS
Tomb Raider DX12 Average FPS
Tomb Raider DX12 Minimum FPS
Civilization 6 DX12 Average FPS
Civilization 6 DX12 Minimum FPS
Tom Clancy's The Division DX12 Average FPS
World of Tanks Average FPS
World of Tanks Minimum FPS
Sick!
1700X / 6800K
123w / 126.87w
62.77w / 98.74w
154.66w / 194.2w
81.55w / 113.5w
Newsfiend
Thanks for that translation. So the only test where ryzen really falls behind is Ludashi 5.15 Memory score which given the ram speed disparity between the two systems shouldn't be surprising.
1 - 20 of 335 Posts
