1 - 3 of 3 Posts
Ok, I've tightened my timings and went to go check them again in CPU-Z and it shows blanks.
Also can someone tell me what I should set my bank interleave to? And what are trfc, trrd, twtr, and twr? And what do they do?
The same thing happens to me(and to every one) when i run it in safe mod...
Check if your privacy guard isn't blocking it as a manner of protecting system resources, Even if it doesn't try to create a custom authorization for CPU-z...
Also Undo any tweaking you have done(Service disabling perhaps).
My speculation dont fit the circumstances but those tips worth checking...
1 - 3 of 3 Posts
