1 - 13 of 13 Posts
Heya all,
I have a 450 gb raptor for my main drive that has my OS. I strictly use that for my OS Drive and I use my 2nd drive that is a wd black 1tb for storage.
I am getting a WEI for my HD at a disappointing 6.1 considering what im running.
Any ideas on why this may be happening. I dont have a raid setup right now.
any info would be appreciated.
Thanks,
Its a mechanical hard drive, what do you expect?
I actually find it odd that you're getting 6.1 instead of 5.9. Usually 6.1 and 6.2 is RAID0 + Short Stroke territory.
Either way, its WEI, so it really makes no difference either way. Sit back and enjoy your Raptor and forget about the horrible thing that is WEI.
Oh, and if you REALLY want to increase your WEI (pointless, but whatever), then get a SSD, as that's the only way you'll get it higher. Wouldn't be a bad idea anyway, but not JUST for WEI though.
Feel lucky honestly. Most raptors get 5.9. In fact I thought it was impossible to get above a 5.9 with a mechanical HDD of any kind. Post a screenshot?
I get 6.2 with my F3's in RAID0 and short stroked.
It is very VERY difficult to get higher though. WEI scores for hard drives is based off access time if I'm not mistaken, and mechanical drives just don't have that.
SpaceStationGaming
Or just edit the file
Originally Posted by Alex420
Heya all,
Thanks,
Um, what were you expecting?
Even with RAID0 you're not going to achieve top WEI score
1 - 13 of 13 Posts
