1 - 3 of 3 Posts
Does it work?
I'm looking to make a PSU shroud with black acrylic
I have only had luck with acrylic cement, but have never tried crazy glue. Here is a link to the one I use when I work with acrylic - CLICKY
This is fast setting stuff - Weld On 4 is a bit slower.
Originally Posted by Rognin View Post
Does it work?
It does work, but not very well. Cyanoacrylate (CA), or commonly known as super glue, will leave some crazing when you try to use it to glue Acrylic together. It wont leave a very clean finish. With black acrylic, CA will leave a lot of crazing. I highly recommend using a cement which literally welds the two pieces together. The cement melts the two pieces and fuses them into one. Look for an acrylic cement instead of CA, it will be much cleaner and much stronger.
1 - 3 of 3 Posts
