1 - 8 of 8 Posts
at this moment my computer is sucking in air from outside that is about -4 Degrees Celsius, normally it will get down to anything from 0 to 4 degrees Celsius with my freezer pro 7, well i went home from college for the holidays and i think that my cooler might have been jarred in transport, the coolest i am getting with AMD Cool and Quiet and C1E on at stock everything is about 17-25 degrees Celsius. is this off or am i crazy??
Originally Posted by SS_Patrick;12026822
I wouldn't complain with those temps
You could try reseating the heatsink and go from there
well the part that is bothering me is that i used to get lower temps than that at a much higher voltage with a quite good OC, but now at stock i am running hotter than my OC did
also reseating means new TIM right??? any suggestions i have never had to do any of this before and am kinda a noob at all this kinda maintenance
Scrub since 2010
^^^ This
I would Marry those temps
Do what he said... Try a reseating
very simple .... first (GET AWAY from the cold temperature), heat up your computer for like 30 minutes... so that the current TIM gets softer...
Turn it off... then Remove the heatsink.... then use cloth + Rubbing Alcohol to clean the old TIM from the Heatsink & the CPU... afterwards... add 1 single pea sized drop on the center of the CPU & place back in the heatsink.
that is the basic way to do a reseating
Originally Posted by sendblink23;12026878
^^^ This
what though, is there one brand or type that is better??
well i know i need to do this pretty fast, i closed my window and ran it for a wile and it idled at 42 C that is a little warm for a Athlon II
Discussion Starter · #8 ·
ok quick simple question to go along with this, i dont actually have any rubbing alcohol seeing as i am at my dorm not at home but i do have some alcohol prep pads from a small medical kit i got, will these work just as well???
1 - 8 of 8 Posts
