1 - 6 of 6 Posts
Is this possible? It's really annoying to start the service and end it when playing certain games (BF2, CSS)
yeah, right click Properties of the service, copy the "path to executable" and place it in a new shortcut
Reactions: Glueeater
or you can make a bat file
Make a new .txt file and in there type
NET START (service name goes here)
save it and replace the .txt with .bat
Then you have a working service starter ^_^
What if the executable requires a switch? For example... the print service. Spoolsv.exe won't start when you just run it, so I would assume it needs a switch.
I tried this for the print spooler and got "The service name is invalid." That is the result of "net start print spooler".
Discussion Starter #6
I'm guessing NET STOP ends the service?
I saved this as a bat file
NET START "[email protected]+Program [email protected]+FAH504-Console.exe"
But the service won't start...the dos screen just flashes and goes away.
EDIT: Nevermind solved... Reps+
EDIT 2: A note for people reading this thread...you can also place these .bat files in C:\\Windows\\ and then execute them from the run command....Its very convient, just WINDOWS KEY+R then type whatever you named the bat.
1 - 6 of 6 Posts
