➡ What Is It?
4K x265 (HEVC) Benchmark is an easy to use benchmark created by me for the OCN community (I decided to create this after it was suggested that Handbrake should be used to benchmark, which is not only far more complicated that it should be, but it also advocates for terrible software).
This benchmark utilises AVX (AVX, AVX2, and AVX512 if your CPU supports it) and is simple to run. It takes approximately 6 minutes to complete on a 12C/24T CPU. An included 10-bit 4K video file (Creative Commons) is encoded to 5,000 frames (03m 28s). If all 5,000 frames are encoded, a line of results is produced containing the following information:
The current x265 encoder version is 3.5+21-3898a4996 (Jan. 2022 compile)
➡ Does it Work?
Yes. I've done as much testing as is possible and this is being actively developed (it's taken about 15 hours to get to a releasable state). If you find any problems, please let me know.
➡ How Long Does it Take?
That entirely depends upon your CPU, whether it's overclocked, RAM clocks, and other factors. Here are a few examples showing approximate benchmark times on selected CPUs:
No. The benchmark is entirely portable. You simply need to open the "Start Benchmark" file, read the short piece of information displayed, and then press any button to start the benchmark.
➡ Is The Benchmark Safe?
Yes. Here are the two primary files used in the benchmark. They have been scanned with VirusTotal and you can see the results by clicking on the link.
➡ Where Do I Download It?
Download (pCloud): 4K_x265_HEVC_Benchmark-v0.1.2.zip
SHA256 (pCloud): 4K_x265_HEVC_Benchmark-v0.1.2.zip.md5
➡ Posting Results
Please post:
This is purely a demonstration as I had about 90 tabs open and 30 explorer processes running when running this benchmark. I did it to take the screenshots to post here. I will post my actual score later on.
This is the screenshot that should be posted. It displays the fps, kbps, and CPU model.
Feedback is welcome.
- If the benchmark completed without errors ("SUCCESS")
- How long the benchmark took to complete (in seconds)
- How many frames were encoded per second (fps)
- The data/bit rate for encoding (kb/s)
- Average QP (not yet relevant, but will be in future versions)
- The date and time in local format (e.g. 🇬🇧 & 🇪🇺 = dd/mm/yyyy with a 24h clock, 🇺🇸 = mm/dd/yyyy with a 12 hour clock)
- CPU details, including the brand and model (this will be changed in future version to include cores and logical processors (threads))
➡ Does it Work?
- AMD Ryzen 9 5950X: ~3m 45s
- Intel Core i9-12900K: ~4m 30s
- AMD Ryzen 9 5900X: ~6m
- AMD Ryzen 7 5800X: ~7m
- Intel Core-i9 9900K: ~8m
- Intel Core-i5 1035G4: 31m (Surface 7 Pro)
➡ Posting Results
Please post:
- A screenshot of your score
- If your CPU is overclocked (e.g. "Intel 12900K @ 5.2 GHz")
- Your RAM clocks and generation (e.g. DDR4 3600 / DDR5 5200 )
