1 - 5 of 5 Posts
ok so some of you guys saw my first mod
http://www.overclock.net/case-mods-g...-some-fun.html
with the samsung case.. it's sloppy and needs major improvement obviously but i still love it
and i wanna keep the form going...
Here is my problem....
I want to pull the hardware out of the old plastic hardshell case and put it in the case to the right of it...
The one on the right is not nearly as tall.. i lose at least a full inch.
As you can see, i lose much needed airspace and wont be able to shut the case. due to 1)the cooling fan on the sidemount CPU and the Power supply...
a prime example of my delimma....
so.... lets hear some insight?
:withstupi
could you cut a hole for the fan (exhaust). then maybe cut another hole for the psu and maybe construct a small box on top of the case to accomodate the psu? also are there any smaller psu's? i have seen some small ones.
what would putting the cold catchode lights and fans acomplish????
i'm talking about i'm needing more headspace.... the hinges are the biggest i can get for that case barring the idea of not having it sealed when it's closed
that the power unit ON button will only work when the numbers on the combo locks are set to 000 000 or something like that....
is that even possible?
1 - 5 of 5 Posts
