Critique my potential purchases
690 Views 8 Replies 3 Participants Last post by  Veltri
Rietchle vte8 vacuum pumps
Anyone know the micron rating for this thing? Lowest is best, right?
gauges
I can get both the gauges and pump for ~$120, shipped. Considering I'm a weekend warrior, will these be enough or just a waste of money?
1 - 9 of 9 Posts
What temperatures are you planning on running at?
What are you going to use the pump for?
that post was so bad it got 2 facepalms
looks good except 1 thing, doesn't canada use 120volts? that is 230volt. i guess you could bring a step up transformer everywhere you go with it. as for micron rating
try googling for the user manual, i think i may have found it, then i realised i dont have adobe pdf reader installed yet.
Maybe you can explain to me how it was bad then?
I tried googling it for a few hours. Nothing. As for 230v, I've actually got it in my garage's electrical service. Not sure about where you're from but around here houses get 230v service for clothes dryers and things like that.
If you want to use 230v you can, personaly i find it to be an inconveniance in the usa because if you do ever need to take it out of your shop it'll be hell trying to find a 230volt plug, without unpluging a stove or cloths dryer. if your only going to be using it in your shop go for it. the specs seem rely good,and the price is rely good for the price, better then paying $300+ for a name brand one with the same specs.
excuse me for being an ass. its the dang wisconsin weather over the past coulple weeks.
here is a guide on phase change construction. this should awnser your question and more, if you got any more questions afterwords feel free to ask.
http://www.overclockers.com/index.ph...ng&Itemid=4257
Originally Posted by from link
Probably the most important and expensive item used is a vacuum pump. The main purpose of a vacuum pump is to decrease the pressure inside the system to such an extent that water will boil at room temperature. This water vapor can then be flushed out of the system, leaving a totally dry environment for our refrigerant. This is the vacuum pump I use:
Ok, I see now. You use the vacuum to evacuate the H2O vapor so you don't get: H2O + Hydrochlorofluorocarbons = hydrofluoric acid = bad.
Yes, I am very familiar with the thermodynamic steam and refrigeration cycles; however, I didn't realize he was building this completely from the ground up and would be evacuating the system.
I assumed most people bought self contained systems usually, but I guess its like anything else, why buy, when you can build your own, better system.
I've decided to go for it. Looks like I'm gonna win to auction *fingers crossed*. Also, I have a generator that does 220 so if I need to move it I'm cool.
*update*
I got sooooo majorly $hitfaced at a campus pub today that I missed critical final moments of the ebay auction. Dang. No pump for me. Haha, oh well. Another victim of St. Pat.
:swearing:
1 - 9 of 9 Posts
