The kit is Patriot Viper 3 1866 CL10 in an Asus P8Z68-V GEN3 motherboard with an i5 2500K @ 4600MHz (static). Once RAM timings have been finalized, the CPU will be increased to the highest frequency it can hit with 100MHz FSB between 1.32 and 1.35V.
Frequency: 1866MHz overclocked to 2133
Timings: 10-11-10 overclocked/changed/changed to 10-12-11
Voltage: 1.5V XMP running at 1.65V (for now, lowering after tweaking, probably by ~0.02-0.03V)
I've only ever spent a few hours specifically reading up on overclocking DDR3 back in 2011 when I got the CPU in the machine this is for. I lost interest really - undervolted the chip to ~1.2V and overclocked to 42-4400MHz and left the RAM at its XMP timings and clock speed (1600MHz), with a slightly lowered voltage (by 0.07V to 1.58V. This was to keep Intel's stated mandatory 0.5V maximum difference between VCCIO (VTT) and DRAM for Sandy Bridge (and some other) processors.
A little bit below is a graphic I made using a screenshot of AIDA64's northbridge (RAM timings) page and MSPaint to outline the timings I have.
Purple is as low as it'll go without causing errors at 2133MHz
Green will go lower but hasn't been checked for errors during operation
Small blue dash underneath means no BIOS access to the timing (thankfully they're all pretty much low enough)
tRFC at 220T is stable, 204 errored. It's up at 240 until all others are finished, at which point I will lower it to 10 over what generates errors in a hot case
This is 3T RAM (weird, I know), so 2T is it "optimized". It wouldn't do anything at any useful frequency at 1T
Purple stars mean the BIOS doesn't allow a lower number to be set. Eg. tRRD of 4? Press minus and 4 changes to Auto - press plus and 4 changes to 5. No 3!
tWR is at 10. Like tCL, but 2 higher than tCWL. I haven't tested it lower - does anyone know if there are any benefits lowering it? Or will other timings effectively limit any performance gains it would otherwise cause if they were lower?
tREF of 9999 is the highest number (unfortunately). It's like DDR4's 65000 being ripped off to 25-28K. But it's at its highest and best option, unless someone knows something I don't and I should lower it?
My biggest curiosity is tRAS. It's set to 31, which I've heard is perfect because one less than CL + tRCD + tRP is said to be optimal, and 10+12+11-1 = 31
Is that rule correct?
