1 - 9 of 9 Posts
Yesterday I was tidying up my wires in my computer (specs below), when I noticed the heatsink is crooked a bit, from the left to right it's about a 1/4 inch.
My temperatures are fine and my system is stable, but in all likelihood I will probably try and re-set it. Should I take out the entire motherboard, or do this with the motherboard still installed in the case?
I'll upload pics when I get home from work.
Hmm, I'm not sure. I have a Lian-Li PC-K58, pic below:
Are you referring to that large hole at the upper-left? All I see there is the backplate.
What if the entire CPU is still being covered by the heatsink, is it still necessary to fix it? I'm not lazy, but this was my first computer build and I don't want to break anything if I can help it. Thanks for the help.
Retired Reviewer
1 - 9 of 9 Posts
