1 - 18 of 18 Posts
Hey, I am building a computer for the first time and i am wondering if i can use an ATI GFX card in an nVidia based mobo.
ATI seems to have the best low-end bang for the buck.
Believe it or not, I did it, using the X850XT on the A8N-SLi Deluxe Board. I wouldn't suggest using it in crossfire, but you'd have an interesting hack to talk about if and when you got it fully completed. Good luck with that.
In my personal and honest opinion, though..... if you're going ATI with an ATI rig, try an ATI southbridge chipset. The best ones built are the Xpress 3200 chipsets, so keep an eye out for those.
Nvidia, the same..... go for type specifics. You know they work.
~Keep the pimp hand strong~
Go for the nvidea chipset with an ati card. No hack required.
Discussion Starter #6
Oh really? Thats good. Thanks for telling me.
I guess Zorpnic just got the regular results and didnt get lucky
I think i will go ATI because you get 256 bit memory and GDDR3 for cheaper.
Thank You
Whats your budget? We will help choose the perfect card for it.
Discussion Starter #9
my budget? for the whole system the MAX i can spend is about 450, so not alot of room for nice GFX(This is a secondary computer, I already use a Dell Dimension 9150 1 year old 1 gig ram, 256 mb video, crappy dell mobo Pentium D 820)But i do have a salvaged case, drives, sound card, and usb hub.
Filthy Casual
Someone modded soem BIOS to run 2 crossfire cards in SLI... can't remember who it was, though.. sorry.
Ok, heres a build which would soon be diminished by Chozarts ^^
https://secure.newegg.com/NewVersion...asp?ID=3236309
Not sure if that will work, tell me if it doesn't.
EDIT: Oops, forgot the ram, hang on, let me sort this out.
Ultra Low End:
7300GT
Midrange:
X1650Pro
High-Midrange:
7600GT
Low-High End:
7900GS, X1900GT, X1950Pro
High End:
7950GT, 7900GTO, X1900XT
Ultra High-End:
X1950XTX, 7900GTX
Uber:
7950GX2
Get the one that suits you
https://secure.newegg.com/NewVersion...tTitle=Here+ya
BIOSTAR K8T890-A9 Socket 939 VIA K8T890 ATX AMD Motherboard - Retail
Model #: K8T890-A9
Item #: N82E16813138021
Return Policy: Standard Return Policy
In Stock
$56.99 $56.99
Update
BIOSTAR V7602GS21 Geforce 7600GS 256MB GDDR2 PCI Express x16 Video Card - Retail
Model #: V7602GS21
Item #: N82E16814141031
In Stock
$102.99 $102.99
Update
FSP Group (Fortron Source) AX450-PN, 12cm FAN, version 2.0, 2 SATA, PCI Express, 450W Power Supply - Retail
Model #: AX450-PN
Item #: N82E16817104954
In Stock
$51.99 -$3.00 Instant $48.99
Update
AMD Athlon 64 3700+ San Diego 2.2GHz Socket 939 Processor Model ADA3700CFBOX - Retail
Model #: ADA3700CFBOX
Item #: N82E16819103622
Return Policy: Processors (CPUs) Return Policy
In Stock
$96.00 $96.00
Update
Patriot 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) System Memory Model PSD1G400 - Retail
Model #: PSD1G400
Item #: N82E16820220030
In Stock
$119.99 -$15.00 Instant $104.99
Update
Seagate Barracuda 7200.9 ST380811AS 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Total:$455 not including shipping. Best I could do. You could also add another stick of ram in later on for 2gbs
Model #: K8T890-A9
In Stock
$56.99 $56.99
Update
Model #: V7602GS21
In Stock
$102.99 $102.99
Update
Model #: AX450-PN
In Stock
Update
In Stock
$96.00 $96.00
Update
Model #: PSD1G400
In Stock
Update
nicely done not sure even the mighty chozart could beat that lol
Originally Posted by NrGx
Ultra Low End:
7300GT
Midrange:
X1650Pro
High-Midrange:
7600GT
Low-High End:
High End:
Ultra High-End:
X1950XTX, 7900GTX
Uber:
7950GX2
That is very personal, IMO.
I'd like to see proof of this one.
There's only a couple of configurations available through crossfire, what with the cable you need, and the various types of dongle ends on them. I don't see how it'd be possible to do it, without losing a monitor/DVI-I. Find out who it was, if you can, and post it here.
Discussion Starter #18
well, imma go with my personal build(as seen in the thread "best for the EXTRME budget?" and start w/ intergrated and then buy an eVGA 7600 GTS
1 - 18 of 18 Posts
