1 - 6 of 6 Posts
everything max is about right @ 1920x1080
Originally Posted by lmsc1969 View Post
It only run at around 60 using fraps
I dont know if i should tune the card in cc setting of videocard or just leave it has it is.
First off, just want to make sure, but is V-Sync enabled?
Secondly, if using MSAA maxed, that could really drop it further. I was just giving a standard gauge for about 2xMSAA. 4x and up will definitely drop performance. Try FXAA High. Looks about the same, except the little blur effect on the picture.
1 - 6 of 6 Posts
