1 - 5 of 5 Posts
While surfing on the web, I came across a deal of a x800 256 pci-e crossfire edition for $100. So I was wondering, how would a pair of x800 crossfire edition cards compare to say a x1950pro which is about $200. Two is better than 1 or crossfire only boost the performance to a certain limit?
probably close to the same I would say. The X1950PRO is newer technology.<br />
<br />
The main issue is that the X8xx series does NOT support sm3.0. Also, the X19xx series are more powerful, and I think a single X1950PRO will give dual X800's a good run for the money.<br />
<br />
I'd get a single X1950PRO (and hey, you then have the option to add a second one <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />)
<tr>
<div>
Originally Posted by <strong>Chozart</strong>
</div>
<div style="font-style:italic">probably close to the same I would say. The X1950PRO is newer technology.<br />
<br />
<br />
I'd get a single X1950PRO (and hey, you then have the option to add a second one <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />)</div>
</td>
</tr>
</table>
</div><br />
i agree with chozart. 2 cards should theoretically give you 2x the performance but thats not always the case. x1950 pro is a much safer bet.
Also with crossfire dont you have to disable it to .. watch dvds or something.? Id get the 1950 pro its nice. big difference from shader model 2.0 and 3.0
I'd take the x1950. I had SLI, and to be honest...a single card solution is where it's at man. Dual monitors are out if you get crossfire....bigger power drain....<br><br>
No SM3.0, also...
1 - 5 of 5 Posts
