Crossfire = not working.
876 15
SO here's the problem, I have to Asus Radeon 4850's and am trying to xfire them and it's obviously not working. I have uninstalled the last drivers and driver scrubbed. Newest drivers and both cards have power and work (I triple checked).
I can give a little history. Both cards worked in Xfire on an Biostar Tpower i45. I sold that mobo and bought a Asus Rampage Formula, then the problem's started.
I am willing to do just about anything to fix this, including smash the [email protected] cards.
1 - 16 of 16 Posts
Ok so I flashed in the 0701 drivers and crossfire still does not work. Methinks these cards will be sold for something a little more powerful sometime soon.
Have one card in and install the drivers. Shutdown, Put second card in with crossfire bridge. Boot up and try to enable crossfire in CCC
I had a similar problem with my Asus p5e x38. If you can't get crossfire to work with newer drivers, then install them with 8.7 and I bet they will work. Then you can wait until some new drivers actually work with them.
A few things to try..
1. Update your mobo Bios
2. Disable ATI external event utility
Thats how I got 8.12's to work with my 4850's....
9.2 is working for me right now though.
I 2nd this. I've solved a few xfire problems by doing this.
I have the same motherboard as the original poster. Make sure on your north bridge or chipset setting its set to "PEG/PCI" this fixed my problem of no screen. Put one card in and install driver just like the others have said. What I did after that was put the other card in without the bridge to make sure I have display. Ignored the message saying it needs the bridge to enable crossfire. Than I rebooted and put the bridges, booted, on CCC, enabled crossfire and voila.
I had similar problem, with my asus m3a78-t mobo. i had 3 pci-e slots, one closes to the cpu, then others. I plugged one of my vid card to the one closest to the cpu, then the last one closest to the bottom. and that didnt work, so i moved the last one to the middle pci-e slot, which doesn't give much room but a piece of paper. and it worked. only downfall is. it only runs 16x/4x. But its better then 8x/8x.
Discussion Starter · #16 ·
Ok here's what happened: I uninstalled 9.2, swept drivers, installed 1 gf card, installed dirvers, installed the second gf card, got CF working, tested it out, and now DX 9 no longer works. I did the above process again minus the working part. Any ideas?
P.S. these cards might do better from a couple stories down on the pavement.
P.S.S. I was gone for a long time due to finals.
1 - 16 of 16 Posts
