1 - 4 of 4 Posts
no you cannot CF a HD 6870 and HD 7770. the best option for you would be to sell your HD 6870 and go for a faster single GPU like HD 7870 Tahiti LE or HD 7950. what psu brand/model do you have ? how many amps on +12v rail ? which country are you from ?
if you sell your HD 6870 you can get USD 100. so if you can spend USD 150 more get a HD 7870 Tahiti LE. you could also save up a bit more and spend USD 190 to get a HD 7950 boost.
Sapphire HD 7870 XT - 250 ( 235 after rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202024
Sapphire HD 7950 boost - 290 (270 after rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
HD 7950 boost is a doubling of performance from your current card. at same clocks HD 7950 is 5% slower than HD 7970. HD 7950 boost easily overclocks to 1100 Mhz and matches HD 7970 Ghz
http://www.techpowerup.com/reviews/HIS/HD_7950_X2_Boost/28.html
1920 x 1200
HD 6870 - 55
HD 7950 iceq x2 boost - 100
HD 7970 Ghz - 115
HD 7870 Tahiti LE is 15% slower than HD 7950 boost. at the same clocks its close to 20% slower.
http://www.techpowerup.com/reviews/Club_3D/HD_7870_jokerCard_Tahiti_LE/31.html
1 - 4 of 4 Posts
