The threat title may make it sound easy. But here is the situation.
I flashed my Asus Crosshair motherboard with the newest version of bios. after the boot up screen it goes to load windows and i get an error saying "error loading OS" So i find out that the bios update switched my raid drive as primary and my main OS HD as secondary. Now that i fixed that, windows run fine. It wont detect my XF-i Xtreme Audio Card. It shows it plugged in and with updated *this device is working* but doesn't work. Volume's up still nothing, un-installed all the proper files and then re-installed,etc. Tried finding a section under BIOS to see if it's deselected. Can't find anything.
Got any pointers to help me out?
Thanks,
Adam
Thanks,
Adam
