I'm sick of my crappy white CRT. I want to paint it however I'm not sure what kind of paint I should use. I work at Ace Hardware so I'm familiar with the Krylon brand. In this type of application would it be better to use a primer and auto paint or use the krylon fusion meant for plastic? As far as I can tell the case is made out of metal, but it feels like plastic.
Thanks for your input,
Ken
Also Is there anything else I should do to it while its disassembled?
Pictures:
Ken
Pictures:
