1 - 2 of 2 Posts
I am thinking of getting 4 ballistix tracers for the dfi sli-dr expert board im getting. does the fact that i have to run it at 2t make it so that there will be a huge performance hit as opposed to getting 2gb kit gskill hzs? Also, does 2t have a huge impact on overclocking?
Administrator
Well for a start AMD memory controllers will get stressed running 4x Memory modules of any sort. A DFI motherboard can run in 1T with 4X 512. However if they are 1gb sticks you will run in 2t. No 2T doesnt have a large impact onm overclocking at all. Infact Looser timings on RAM can add stability.<br><br>
Having 2GB is plenty and will serve you well.
1 - 2 of 2 Posts
