Which is better on A64 S939
  • Crucial Ballistix
    Votes: 2 11.1%
  • OCZ EL Platinium rev. 2
    Votes: 16 88.9%
1 - 20 of 26 Posts
What ram is better the Ctucial Ballistix or the OCZ EL Platinium rev. 2 for OCing on the dfi lanpaerty nf4 sli-d and amd 3200+. Becuase the guy who I'm buying the components said that the crucial is better, but almost everybody here says that the the ocz is better. I know that the ocz is better on the intel but what about A64 any experiances with this ram?
Rep points for the first usefull reply!!!
Thx guys
Thx guys
OCZ = king of ram....
Originally Posted by PCnerd2357
The OCZ is ddr500 so ya can get your fsb to 250Mhz at 1:1 with no sweat with that ram
Wrong, it's DDR400... They don't make Rev. 2 Platinum in anything but PC3200.
ohhh, so were not talking about this stuff
no....the 3200....but its not the same kind....and the 4000 is not as good at all.
i vote for the 3200 platinum, it is awsum ram, and can get to like 260fsb easily...
and just for comparison...even yiffy is looking to get some...so that must mean its good
i have ocz platinum 3200....but its not rev2
That's good stuff too, the only difference is in the timings... Your's is factory 2-3-2-6 i believe and the Rev. 2 is 2-2-2-5.
get the OCZ /... that stuff oc's sooo well
Xp got it up to 300 (I bet he posted already)
bbut yea your gonna get 270 out of it min.
I am buying some my self... but I've decided since i've gotten more money.. it may be time to get rid of this 9600 instead
It does OC extremely well
I've got mine at 290 right now and I'm looking to take it to 300 when I swap out my XP-90 for an XP-120.
Discussion Starter · #16 ·
You OCed you 3000+ to 4000+ wow with air cooling. Ok by the results I'll buy the OCZ. And by the end off te week I'll have my new pc up and running
Yeah i'm rapidly approaching a 1ghz aircooled overclock, lol. It's starting to get burnt in at this speed, by the time I get an XP-120 it should be ready to go for the next 100mhz
Discussion Starter · #18 ·
Were you lucky and got a good cpu or do all OC like that?
**Edited***
What are the temp.?
**Edited***
What are the temp.?
I don't know if I'm "lucky" or not, but I have a great set of surrounding components that didn't hurt at all
Currently running 38*c idle and 53*c full load.
Discussion Starter · #20 ·
So if I get dfi lanparty nf4, ocz el platinium rev. 2 and 3200+ it should OC to 4000+?
1 - 20 of 26 Posts
