No, the white or gray one it was plugged in on the top though all i did was plug it in on the bottom.Originally Posted by TwoCables;15311206
Did you go from the navy blue port to a white one? If so, then that's why. The navy blue port are the crappy Marvell-controlled ports.
/\ this.Originally Posted by TwoCables;15311206
Originally Posted by TwoCables ![]() Did you go from the navy blue port to a white one? If so, then that's why. The navy blue port are the crappy Marvell-controlled ports. |
Originally Posted by Ganglartoronto ![]() Are the white ports on THIS mobo marvell? I use the blue ones. Im getting an ssd in the mail this week so I want to know which I should use. |
0.o thats ridiculously fastOriginally Posted by Cheaptrick;15326337
I've only used my (2) Crucial M4 128 Gb SSDs on RAID 0 for 2 days. Just wondering if the result I got is a typical result for a RAID ) set up.
OK, my SSD is working then. I'm not so familiar with this SSD benchmark so I asked.Originally Posted by Zeek;15326368
