1 - 8 of 8 Posts
Ok so my older computer has 2 gb, 2x1gb. When I go to computer/properties, it says I have 1.75gb ram which is right.
But when I use crucial it takes ages, then says I only have 1gb stick, whereas on the computer it still says I have two.
Why is crucial getting it wrong?
How do I know which is ram port 1 or 2?
Overclock Failed...
Your motherboard's Owners Manual will identify the slots. It will also tell you which slots (ports?) to put your sticks into. If you don't have a manual you can download a copy from the motherboard manufacturers website.
I don't know what you mean by "when I use crucial". What is crucial? Can you post a link to what you're using?
Well I have my ram sticks in the correct place because this is how the computer came.
So if I download the manual it will tell me what to look for when purchasing new Rams?
The website scans your system and tells you which ram you will need. Maybe crucial isn't that reliable if it's saying I only have 1 ram connected when I actually have two Rams connected. The site is www.uk.crucial.com/gbr/en/systemscanner
I've no idea what I'm doi
Just a nitpick here - I have no idea why people say Rams, I also have no idea why it annoys me so much. RAM or RAM Sticks, not RAMs, please.
Secondly. A Link to or more information on the computer you're scanning please?
Overclock Failed...
So you just assume whomever installed the sticks did so correctly?
Many motherboard manufacturers will list (on their websites) memory they have tested with a particular motherboard. That won't be all the memory that will work, just what they tested...
Use the "advisor tool"
Why are you replacing your memory?
What motherboard, memory and CPU do you have now?
Scan tool linked from the system advisor scans my system just fine.
Something you want to be sure of is the seating of the memory. I have seen 4.00GB Memory installed, but only 1.7GB usable on my system before, due to improper seating.
*cough* Stock *cough*
I am guessing it is just a detection issue.
I mean if you see 2 sticks, well yeah you have 2 sticks(assuming the right capacity shows up and they are fully seated.).
And for something interesting, It DOES see that I only have 2 slots on this system and that I have 2 x the max "supported" memory.
It is also interesting that it does not see my primary storage drive(guess it picks whatever is the largest.).
Blessed to Serve
The crucial scanner seems to do much better with prebuilt Dells and HPs and the like. It's not a perfect tool, but it is pretty good. It may run into trouble on custom setups.
1 - 8 of 8 Posts
