For those of you who are CPU limited and are tired of the low performance in Crysis 3, you may want to check out this video. If you are GPU capped, then you likely won't see any benefit. My results were a 27% FPS increase on a 4945MHz i7 3770K with Tri-Sli GTX 680's. GPU's still had room to go so even 2-card SLI setups should get the same result.
Video:
App Required:
Timer.zip 7k .zip file
Video:
