1 - 20 of 22 Posts
· Programmer
I can't seem to find a Download. All links are broken including Guru3D and crymod links.
Thank you!
· 3DFX User
Reactions: BradleyW
· Programmer
· 3DFX User
Ninja Edit FTW lol.
· Programmer
Discussion Starter · #8 ·
Originally Posted by TheSchlaf
Get off the computer and go outside = Real lifesis. Problem solved.
I can't see any sun rays boucing off palm trees so shut up.
· 3DFX User
· Programmer
ok i will go to the final mod i want, yet i can't seem to find it...again.
Here is a vid of it.
It's called "crysis Photoreal 3 Map"
Please if someone can find this it's rep time.
Think i found it but it's on Cry mod, still down.
· 3DFX User
Reactions: BradleyW
· Game since 3
You should try ReaLoaded, I found it while trying to find Real Lifesis
some ss from my PC:
More here.
Awesome, really. Except the sound has been messed up idk why
but all I care is the look.
· Programmer
Discussion Starter · #13 ·
Rep given. Also i like this mod. I will check it out.
Does anyone know any Autoexec's that make the game look bright like BFBC2?
The Realoaded looks great. Can you give me a DL link that's not directed toward Crymod?
· Game since 3
· Programmer
Discussion Starter · #15 ·
· Game since 3
Readme, readme, readme included
yep, exe. No need to backup anything.
Have fun.
· Programmer
Discussion Starter · #17 ·
ok cool installing now.
· Programmer
Discussion Starter · #18 ·
The mod won't work. I did a clean install of crysis,then patched 1.2 and 1.21 and installed mod then tried loading my save game and it fezzes up when the level is 3/4 loaded.
· Game since 3
Hmm, I think you should try to start a new game. I didn't have any old save game before installing the mod though.
As I mentioned, the sounds in this mod is messed up, so if you only want the look then fine, for a full gaming experience, I'm not recommend it. Try CCC 2.21 instead.
hf.
Try loading the level from the beginning. When installing ToD mods, previous saves won't work.
Console-> map mapname should work, mapnames are
01 Contact = "island"
02 Recovery = "village"
03 Relic = "rescue"
04 Assault = "harbor"
05 Onslaught = "tank"
06 Awakening = "mine"
07 Core = "core"
08 Paradise Lost = "ice"
09 Exodus = "sphere"
10 Ascension = "ascension"
11 Reckoning = "fleet"
Edit: As for the sound, try opening "Game\zzzCrysisREALoaded.pak" and delete the Sounds folder found inside (backup it just in case). It's a shot in the dark though.
1 - 20 of 22 Posts
