So I just ran cs:s using this command
cd ~/.wine/drive_c/Program\\ Files/Steam && WINEDEBUG=-all wine steam -applaunch 240
and here is the results I don't know if everything will fit.
Corrupt JPEG data: 57 extraneous bytes before marker 0xdb
Win32 MiniDump Helper version 1.0.0.0 (c) Copyright 2000-2003 Valve Corporation All rights reserved.
Expected argument 'ProcessId'.
Usage: WriteMiniDump [@argfile] [/?|h|help] [/v|version] [/Type <value>] <ProcessId> <DumpFile>
@argfileRead arguments from a file.
/?Show usage.
/vShow version.
/Type <value>Select dump type values are:
normal
full
ProcessIdSelect process id for which to generate a dump
DumpFileSelect path of output dump file
wine: Unhandled page fault on read access to 0x00000000 at address (nil) (thread 0047), starting debugger...
Unhandled exception: page fault on read access to 0x00000000 in 32-bit code (0x00000000).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:00000000 ESP:0033df78 EBP:7b3f3c40 EFLAGS:00010202( R- -- I - - - )
EAX:00000000 EBX:00000000 ECX:00000001 EDX:00000001
ESI:00000000 EDI:f776c680
Stack dump:
0x0033df78: 7b359297 7b3f3c40 f776c680 7b5193d8
0x0033df88: f776c680 7b5193c4 f776c680 7b5193ac
0x0033df98: f776c680 7b51938c 00000000 00000101
0x0033dfa8: 000001f9 7b35d743 7b3f3c40 0000000f
0x0033dfb8: 7b513da0 0033e010 7b36720d 7b3f3c40
0x0033dfc8: 7ab1f60d 7b3f3c40 7a3bdd54 7b3f3c40
Backtrace:
=>0 0x00000000 (0x7b3f3c40)
0x00000000: addb%al,0x0(%eax)
Modules:
ModuleAddressDebug infoName (95 modules)
PE 400000- 43e000Deferred writeminidump
ELF79fe1000-7b800000Deferred fglrx_dri.so
ELF7b800000-7b93a000Deferred kernel32<elf>
\\-PE7b810000-7b93a000\\ kernel32
ELF7bc00000-7bcb6000Deferred ntdll<elf>
\\-PE7bc10000-7bcb6000\\ ntdll
ELF7bf00000-7bf04000Deferred <wine-loader>
ELF7d5fd000-7d613000Deferred midimap<elf>
\\-PE7d600000-7d613000\\ midimap
ELF7d613000-7d639000Deferred msacm32<elf>
\\-PE7d620000-7d639000\\ msacm32
ELF7d639000-7d651000Deferred msacm32<elf>
\\-PE7d640000-7d651000\\ msacm32
ELF7de52000-7de59000Deferred libogg.so.0
ELF7de59000-7de84000Deferred libvorbis.so.0
ELF7de84000-7df7e000Deferred libvorbisenc.so.2
ELF7df7e000-7dfce000Deferred libflac.so.8
ELF7dfce000-7e007000Deferred libdbus-1.so.3
ELF7e007000-7e073000Deferred libsndfile.so.1
ELF7e073000-7e07c000Deferred libwrap.so.0
ELF7e07c000-7e082000Deferred libxtst.so.6
ELF7e082000-7e0cc000Deferred libpulsecommon-0.9.19.so
ELF7e0cc000-7e10c000Deferred libpulse.so.0
ELF7e10c000-7e115000Deferred librt.so.1
ELF7e115000-7e1dd000Deferred libasound.so.2
ELF7e1f1000-7e1f8000Deferred libasound_module_pcm_pulse.so
ELF7e1f8000-7e22f000Deferred winealsa<elf>
\\-PE7e200000-7e22f000\\ winealsa
ELF7e22f000-7e2b6000Deferred winmm<elf>
\\-PE7e240000-7e2b6000\\ winmm
ELF7e2b6000-7e2ca000Deferred comm.drv16.so
PE7e2c0000-7e2ca000Deferred comm.drv16
ELF7e2ca000-7e2df000Deferred system.drv16.so
PE7e2d0000-7e2df000Deferred system.drv16
ELF7e2df000-7e37d000Deferred krnl386.exe16.so
PE7e2f0000-7e37d000Deferred krnl386.exe16
ELF7e37d000-7e393000Deferred psapi<elf>
\\-PE7e380000-7e393000\\ psapi
ELF7e393000-7e3e4000Deferred dbghelp<elf>
\\-PE7e3a0000-7e3e4000\\ dbghelp
ELF7e411000-7e50e000Deferred ole32<elf>
\\-PE7e430000-7e50e000\\ ole32
ELF7e524000-7e557000Deferred uxtheme<elf>
\\-PE7e530000-7e557000\\ uxtheme
ELF7e557000-7e562000Deferred libxcursor.so.1
ELF7e562000-7e568000Deferred libxfixes.so.3
ELF7e568000-7e56c000Deferred libxcomposite.so.1
ELF7e56c000-7e575000Deferred libxrandr.so.2
ELF7e575000-7e57f000Deferred libxrender.so.1
ELF7e57f000-7e585000Deferred libxxf86vm.so.1
ELF7e585000-7e588000Deferred libxinerama.so.1
ELF7e588000-7e5a9000Deferred imm32<elf>
\\-PE7e590000-7e5a9000\\ imm32
ELF7e5a9000-7e5ae000Deferred libxdmcp.so.6
ELF7e5ae000-7e5cc000Deferred libxcb.so.1
ELF7e5cc000-7e5d0000Deferred libxau.so.6
ELF7e5d0000-7e6ff000Deferred libx11.so.6
ELF7e6ff000-7e70f000Deferred libxext.so.6
ELF7e70f000-7e72a000Deferred libice.so.6
ELF7e72a000-7e733000Deferred libsm.so.6
ELF7e74e000-7e7ed000Deferred winex11<elf>
\\-PE7e760000-7e7ed000\\ winex11
ELF7e823000-7e84a000Deferred libexpat.so.1
ELF7e84a000-7e877000Deferred libfontconfig.so.1
ELF7e877000-7e88d000Deferred libz.so.1
ELF7e88d000-7e90c000Deferred libfreetype.so.6
ELF7e90d000-7e912000Deferred libuuid.so.1
ELF7e927000-7e93b000Deferred lz32<elf>
\\-PE7e930000-7e93b000\\ lz32
ELF7e93b000-7ea09000Deferred comctl32<elf>
\\-PE7e940000-7ea09000\\ comctl32
ELF7ea09000-7ea67000Deferred shlwapi<elf>
\\-PE7ea20000-7ea67000\\ shlwapi
ELF7ea67000-7ebf8000Deferred shell32<elf>
\\-PE7ea80000-7ebf8000\\ shell32
ELF7ebf8000-7ec68000Deferred rpcrt4<elf>
\\-PE7ec10000-7ec68000\\ rpcrt4
ELF7ec68000-7ecc1000Deferred advapi32<elf>
\\-PE7ec70000-7ecc1000\\ advapi32
ELF7ecc1000-7ed4b000Deferred gdi32<elf>
\\-PE7ecd0000-7ed4b000\\ gdi32
ELF7ed4b000-7ee59000Deferred user32<elf>
\\-PE7ed60000-7ee59000\\ user32
ELF7ee59000-7ee65000Deferred libnss_files.so.2
ELF7ee65000-7ee70000Deferred libnss_nis.so.2
ELF7ee70000-7ee78000Deferred libnss_compat.so.2
ELF7ee7a000-7ee93000Deferred version<elf>
\\-PE7ee80000-7ee93000\\ version
ELF7efbf000-7efe5000Deferred libm.so.6
ELF7efe9000-7f000000Deferred libnsl.so.1
ELFf7494000-f7498000Deferred libdl.so.2
ELFf7498000-f75dd000Deferred libc.so.6
ELFf75de000-f75f7000Deferred libpthread.so.0
ELFf7612000-f774d000Deferred libwine.so.1
ELFf774f000-f776d000Deferred ld-linux.so.2
Threads:
process tid prio (all id:s are in hex)
00000008 steam.exe
00000042 1
0000003d 0
0000003c 0
0000003a 0
00000039 1
00000038 1
00000037 1
00000036 1
00000035 1
00000034 1
00000033 1
00000032 1
0000002e 0
0000002d 0
0000002b 1
0000002a 0
00000029 0
00000027 0
00000025 15
00000023 0
00000022 0
00000021 0
00000020 0
0000001f 0
0000001e 0
0000001d 0
0000001c 0
0000001b 0
0000001a 0
00000009 0
0000000e services.exe
00000014 0
00000010 0
0000000f 0
00000011 winedevice.exe
00000017 0
00000016 0
00000013 0
00000012 0
00000018 explorer.exe
00000019 0
0000003e hl2.exe
00000045 2
00000044 0
00000043 0
00000041 0
00000040 2
0000003f 0
00000046 (D) C:\\Program Files\\Steam\\WriteMiniDump.exe
00000047 0 <==
Backtrace:
wine: Unhandled page fault on read access to 0x00000018 at address 0x7a7c094a (thread 003f), starting debugger...
Unhandled exception: page fault on read access to 0x00000018 in 32-bit code (0x7a7c094a).
Register dump:
EIP:7a7c094a ESP:0033e0b8 EBP:00000000 EFLAGS:00010246( R- -- I Z- -P- )
EAX:00000001 EBX:00000000 ECX:00000000 EDX:00000000
ESI:0000000b EDI:7c6148d0
Stack dump:
0x0033e0b8: 7a93faeb 00000000 001a8338 7bc46b6e
0x0033e0c8: 00000000 00000000 00000000 0000000b
0x0033e0d8: 7a93f897 00000000 0033e144 00000328
0x0033e0e8: 7b7a55f0 0000000b 7b7ab484 7c614970
0x0033e0f8: 00000000 7c7bc970 7c6f6860 7c672b28
0x0033e108: 00000000 00000000 7a7affae 7c6148d0
Backtrace:
=>0 0x7a7c094a in fglrx_dri.so (+0x7df94a) (0x00000000)
0x7a7c094a: movl0x18(%edx),%eax
Modules:
ModuleAddressDebug infoName (167 modules)
PE 340000- 376000Deferred tier0
PE 380000- 39e000Deferred vstdlib
PE 3a0000- 3f4000Deferred filesystem_steam
PE 400000- 41c000Deferred hl2
PE d150000- d165000Deferred inputsystem
PE d550000- d64e000Deferred datamodel
PE d860000- d89d000Deferred dmserializers
PE d8a0000- d8c5000Deferred datacache
PE d9e0000- da95000Deferred materialsystem
PE daa0000- dab6000Deferred valve_avi
PE dac0000- db90000Deferred vguimatsurface
PE db90000- dc05000Deferred vgui2
PE dc10000- dc24000Deferred steam_api
PE e1a0000- e1af000Deferred unicode
PE e910000- e946000Deferred soundemittersystem
PE e950000- e96b000Deferred scenefilecache
PE10000000-10030000Deferred launcher
PE20000000-205ef000Deferred engine
PE22000000-22642000Deferred server
PE24000000-24479000Deferred client
PE26000000-26138000Deferred vphysics
PE2a000000-2a0a8000Deferred shaderapidx9
PE2c000000-2c3e3000Deferred studiorender
PE30000000-302cc000Deferred steam
PE38000000-383fd000Deferred steamclient
PE3f000000-3f0aa000Deferred tier0_s
PE3f600000-3f662000Deferred vstdlib_s
PE60000000-60021000Deferred cserhelper
PE628c0000-628d9000Deferred parsifal
ELF79fe1000-7b800000Export fglrx_dri.so
ELF7c295000-7c311000Deferred libgcrypt.so.11
ELF7c311000-7c3b9000Deferred libgnutls.so.26
ELF7c3d4000-7c3fb000Deferred netapi32<elf>
\\-PE7c3e0000-7c3fb000\\ netapi32
ELF7c3fb000-7c426000Deferred secur32<elf>
\\-PE7c400000-7c426000\\ secur32
ELF7c426000-7c43f000Deferred imagehlp<elf>
\\-PE7c430000-7c43f000\\ imagehlp
ELF7c43f000-7c4d2000Deferred crypt32<elf>
\\-PE7c450000-7c4d2000\\ crypt32
ELF7c4d2000-7c51a000Deferred dsound<elf>
\\-PE7c4e0000-7c51a000\\ dsound
ELF7d917000-7d930000Deferred mcicda<elf>
\\-PE7d920000-7d930000\\ mcicda
ELF7d930000-7d95c000Deferred libatiadlxx.so
ELF7d97c000-7d99a000Deferred libgcc_s.so.1
ELF7d99a000-7da2b000Deferred libgl.so.1
ELF7da2b000-7da30000Deferred libgpg-error.so.0
ELF7da30000-7da46000Deferred wbemprox<elf>
\\-PE7da40000-7da46000\\ wbemprox
ELF7da46000-7da5c000Deferred winejoystick<elf>
\\-PE7da50000-7da5c000\\ winejoystick
ELF7da5c000-7da72000Deferred psapi<elf>
\\-PE7da60000-7da72000\\ psapi
ELF7da72000-7dac3000Deferred dbghelp<elf>
\\-PE7da80000-7dac3000\\ dbghelp
ELF7dac3000-7dbf7000Deferred wined3d<elf>
\\-PE7dad0000-7dbf7000\\ wined3d
ELF7dbf7000-7dc2b000Deferred d3d9<elf>
\\-PE7dc00000-7dc2b000\\ d3d9
ELF7dc2b000-7dc4e000Deferred mpr<elf>
\\-PE7dc30000-7dc4e000\\ mpr
ELF7dc4e000-7dca6000Deferred wininet<elf>
\\-PE7dc60000-7dca6000\\ wininet
ELF7dca6000-7dd8b000Deferred oleaut32<elf>
\\-PE7dcc0000-7dd8b000\\ oleaut32
ELF7dd8b000-7ddb0000Deferred msvfw32<elf>
\\-PE7dd90000-7ddb0000\\ msvfw32
ELF7ddb0000-7dded000Deferred avifil32<elf>
\\-PE7ddc0000-7dded000\\ avifil32
ELF7dded000-7de03000Deferred midimap<elf>
\\-PE7ddf0000-7de03000\\ midimap
ELF7de03000-7de29000Deferred msacm32<elf>
\\-PE7de10000-7de29000\\ msacm32
ELF7de29000-7de41000Deferred msacm32<elf>
\\-PE7de30000-7de41000\\ msacm32
ELF7de41000-7de48000Deferred libogg.so.0
ELF7de48000-7de73000Deferred libvorbis.so.0
ELF7de73000-7df6d000Deferred libvorbisenc.so.2
ELF7df6d000-7dfbd000Deferred libflac.so.8
ELF7dfbd000-7dff6000Deferred libdbus-1.so.3
ELF7dff6000-7e062000Deferred libsndfile.so.1
ELF7e062000-7e06b000Deferred libwrap.so.0
ELF7e06b000-7e071000Deferred libxtst.so.6
ELF7e071000-7e0bb000Deferred libpulsecommon-0.9.19.so
ELF7e0bb000-7e0fb000Deferred libpulse.so.0
ELF7e0fb000-7e104000Deferred librt.so.1
ELF7e104000-7e1cc000Deferred libasound.so.2
ELF7e1cc000-7e1de000Deferred libtasn1.so.3
ELF7e1e0000-7e1e7000Deferred libasound_module_pcm_pulse.so
ELF7e1e7000-7e21e000Deferred winealsa<elf>
\\-PE7e1f0000-7e21e000\\ winealsa
ELF7e21e000-7e2a5000Deferred winmm<elf>
\\-PE7e230000-7e2a5000\\ winmm
ELF7e2fe000-7e331000Deferred uxtheme<elf>
\\-PE7e300000-7e331000\\ uxtheme
ELF7e331000-7e345000Deferred lz32<elf>
\\-PE7e340000-7e345000\\ lz32
ELF7e345000-7e35e000Deferred version<elf>
\\-PE7e350000-7e35e000\\ version
ELF7e35e000-7e42c000Deferred comctl32<elf>
\\-PE7e370000-7e42c000\\ comctl32
ELF7e42c000-7e48a000Deferred shlwapi<elf>
\\-PE7e440000-7e48a000\\ shlwapi
ELF7e48a000-7e61b000Deferred shell32<elf>
\\-PE7e4a0000-7e61b000\\ shell32
ELF7e61b000-7e718000Deferred ole32<elf>
\\-PE7e630000-7e718000\\ ole32
ELF7e718000-7e738000Deferred iphlpapi<elf>
\\-PE7e720000-7e738000\\ iphlpapi
ELF7e738000-7e763000Deferred ws2_32<elf>
\\-PE7e740000-7e763000\\ ws2_32
ELF7e763000-7e77e000Deferred wsock32<elf>
\\-PE7e770000-7e77e000\\ wsock32
ELF7e77e000-7e789000Deferred libxcursor.so.1
ELF7e789000-7e78f000Deferred libxfixes.so.3
ELF7e78f000-7e793000Deferred libxcomposite.so.1
ELF7e793000-7e79c000Deferred libxrandr.so.2
ELF7e79c000-7e7a6000Deferred libxrender.so.1
ELF7e7a6000-7e7ac000Deferred libxxf86vm.so.1
ELF7e7ac000-7e7af000Deferred libxinerama.so.1
ELF7e7af000-7e7d0000Deferred imm32<elf>
\\-PE7e7c0000-7e7d0000\\ imm32
ELF7e7d0000-7e7d5000Deferred libxdmcp.so.6
ELF7e7d5000-7e7f3000Deferred libxcb.so.1
ELF7e7f3000-7e7f7000Deferred libxau.so.6
ELF7e7f7000-7e926000Deferred libx11.so.6
ELF7e926000-7e936000Deferred libxext.so.6
ELF7e936000-7e951000Deferred libice.so.6
ELF7e951000-7e95a000Deferred libsm.so.6
ELF7e95f000-7e973000Deferred libresolv.so.2
ELF7e975000-7ea14000Deferred winex11<elf>
\\-PE7e980000-7ea14000\\ winex11
ELF7ea42000-7ea69000Deferred libexpat.so.1
ELF7ea69000-7ea96000Deferred libfontconfig.so.1
ELF7ea96000-7eaac000Deferred libz.so.1
ELF7eaac000-7eb2b000Deferred libfreetype.so.6
ELF7eb46000-7eb5a000Deferred comm.drv16.so
PE7eb50000-7eb5a000Deferred comm.drv16
ELF7eb5a000-7ebf8000Deferred krnl386.exe16.so
PE7eb70000-7ebf8000Deferred krnl386.exe16
ELF7ee79000-7ee7e000Deferred libuuid.so.1
ELF7ee7e000-7ee93000Deferred system.drv16.so
PE7ee80000-7ee93000Deferred system.drv16
ELFf74a5000-f74a9000Deferred libdl.so.2
ELFf74a9000-f75ee000Deferred libc.so.6
ELFf75ef000-f7608000Deferred libpthread.so.0
ELFf7623000-f775e000Deferred libwine.so.1
ELFf7760000-f777e000Deferred ld-linux.so.2
Threads:
00000008 steam.exe
00000042 1
0000003d 0
0000003c 0
0000003a 0
00000039 1
00000038 1
00000037 1
00000036 1
00000035 1
00000034 1
00000033 1
00000032 1
0000002e 0
0000002d 0
0000002b 1
0000002a 0
00000029 0
00000027 0
00000025 15
00000023 0
00000022 0
00000021 0
00000020 0
0000001f 0
0000001e 0
0000001d 0
0000001c 0
0000001b 0
0000001a 0
00000009 0
00000014 0
00000010 0
0000000f 0
00000017 0
00000016 0
00000013 0
00000012 0
00000019 0
0000003e (D) C:\\Program Files\\Steam\\steamapps\\yangas00\\counter-strike source\\hl2.exe
00000045 2
00000044 0
00000043 0
00000041 0
00000040 2
0000003f 0 <==
Backtrace:
... Anyone know a lot about errors and doesn't mind telling me what I need to do to fix the errors or error.
