1 - 7 of 7 Posts
Well i got my x850rpo not to long ago about a 2 weeks or so but i unlocked it and everything and i only get 35 fps on the stress test on all low and my old 9600pro got 50 fps . what is going on here ?
have you tried the test on normal/high settings? . . the in game fps runs a little higher when i have higher settings on mine for some reason?
Did you install the drivers properly? As in, deleting the old ones and installing the new ones. I recommend the latest ones.
Discussion Starter #4
i reinstalled the dirvers and now its at 43 fps
thanks (still think it could be higher though)
Something is very wrong with that score. Did you try testing the card before you flashed it? Also use drivercleaner to remove your drivers and reinstall them.
Discussion Starter #6
well i reinstalled windows completely....ill keep you posted
Discussion Starter #7
Well i reinstalled everything and used WarCat 6.9 drivers and now i only get 40 fps on all high on the video stress test something is REALLY wrong could be a serious bottle neck even though i dont think my cpu or ram or anything else is really bottle necking my video card???
1 - 7 of 7 Posts
