Would this be a bad thing?
I also used to get over 75 FPS (using net_graph 3), now I don't.
cpu speed 3259 MHz Intel 2047 MB of system RAM cpu speed 3259 MHz Intel 2047 MB of system RAM couldn't exec userconfig.cfg Host_WriteConfiguration: Wrote cfg/config.cfg Changing resolutions from (1440, 900) -> (1440, 900) Unable to remove e ![]() couldn't exec userconfig.cfg Host_WriteConfiguration: Wrote cfg/config.cfg maxplayers set to 1 execing game.cfg Spawn Server test_hardware Begin loading faces (loads materials) End loading faces (loads materials) execing skill1.cfg Executing listen server config file Incorrect price blob version! Update your server! ERROR: mp_dynamicpricing set to 1 but couldn't download the price list! Section [Scenes]: 0 resources total 0 bytes, 0.00 % of limit (2.10 MB) Game started couldn't exec listenserver.cfg No pure server whitelist. sv_pure = 0 CAsyncWavDataCache: 649 .wavs total 0 bytes, 0.00 % of capacity Initializing renderer... AddPropOffsetToMap - already found entry [prop: 9 offset: 796] in table for DT_CSPlayer [OCN] GH0 connected Dropped [OCN] GH0 from server (Server shutting down) cpu speed 3259 MHz Intel 2047 MB of system RAM cpu speed 3259 MHz Intel 2047 MB of system RAM couldn't exec userconfig.cfg Host_WriteConfiguration: Wrote cfg/config.cfg Changing resolutions from (1440, 900) -> (1440, 900) Unable to remove e ![]() couldn't exec userconfig.cfg Host_WriteConfiguration: Wrote cfg/config.cfg |
