1 - 9 of 9 Posts
I currently have a XFX ATI 6950 Reference Card in my system (not unlocked) and am looking to add another reference card to my system. Does anyone know where I can find a list of the 6950 Reference cards that are available for purchase today? Every card that I see lately on Newegg is non-reference.
I understand that if I'm going to use Crossfire that two identical cards are the ideal way to go.
Thanks for your input!
RnG
Jack-of-all-trades
might sound low tech but i usually just google the card and use the "shopping" option. it will give you the stores nearest your area as well as websites that sell those stuff.
Reactions: Run N. Gun
AMD Shill
New to OCN?
Originally Posted by LongRod View Post
You could match it up with a 6970, and overclock the 6950 to stock 6970 (it should do that with no problems), and have even more performance, as I can't find any reference 6950's.
Here are some reference 6970's if you choose this way.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150517
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161356
The XFX one is $50 cheaper (with rebate, but I've done rebates with XFX before, they hold through) then the HIS one.
come on w/ that he get a HD 7870 which outpeforms HD 6970 w/o too much OCing
AMD Shill
But then he'd have to get rid of his current 6950, and 2 6950's (or 6970's if you clock them high enough), it would EASILY out perform a single 7870.
Discussion Starter #8
I did that and came up with nothing. Everyone shows it discontinued or out of stock.
That's why I asked here.
Could you get a sapphire HD 6920 2GB which possibly unlock? for 230$ new F.S
I don't think so, I'd really prefer an exact match if at possible.
Thank you for the links, LRod. This is way I may have to go.
Discussion Starter #9
Yes, I thought about just buying the latest/greatest 7970, but that is why I bought this 6950 - it was the best at the time. I was hoping I could just add another 6950 a year down the road (cheaper...) and I would be in a good spot, but I can't find them available retail. I did see a couple of cards on eBay that I may consider, too. It is good to have options.
1 - 9 of 9 Posts
