The problem with most of these articles on the i7 is they spend tons of time talking about the $1000 extreme processor and not enough time with the i7 920.
The i7 920 at $300 is a very cheap processor when it can compare to an existing $1000 core processor.
Sure if you wanna buy two 4870x2's, then by all means get a i7 965 and while your at it you might want to invest in a 3 stage phase changer system for cooling so you can get 5ghz.
The i7 articles are a joke...
A good use for the i7 is a system that uses a 4870 512m with a i7 920. It will run your games at the best settings at 1920x1200 and you will be happy. If you run at higher resolutions then that, then by all means think about the 4870x2 or SLI, but I swear these articles are a waste of time and are catering to the elite and the people that wanna waste a lot of money.
I'm building a i7 920 system sans lcd for a $1600 budget. It's a reasonable system and probably could be had for even less with patience and time in looking for even better deals, then I found.
Anyone building a $3000+ i7 system is just wasting money in my humble opinion.
