1 - 6 of 6 Posts
A thought ocurred to me that the pci-e slot can be used as a landmark to size up other elements of the card. I measured for the width and height of the gpu mount, realising later that the vertical distortion will not be proportional, although the horizontal proportions should be constant.<br />
<br />
x18/x1900 and 78/7900 cards have a 53mm square mounting pattern for the gpu.<br />
<br />
The GF8800 seems to be at least 58mm square, just enough that current coolers wont fit without some modification.<br />
<br />
<img src="http://www.overclock.net/attachment.php?attachmentid=33781&stc=1&d=1161739474" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br><a href="http://assets.overclock.net.s3.amazonaws.com/c/c5/c5a8b7c0_vbattach33781.jpeg"><img src="http://www.overclock.net/image/id/616620/width/525/height/525/flags/LL"></a>
That means a whole new line of coolers for gpu's.. great..
Discussion Starter #4
Im thinkin with some gpu stuff you might be able to drill new holes, or widen out the old ones<br />
<br />
That big IHS is screaming to have a pelt stuck directly to it...
Very nice, extrapolating sizes, from pixels.
Might need something on the little chip to the left too.
1 - 6 of 6 Posts
