1 - 4 of 4 Posts
Hey guys,
My R9 270X died a few months ago and I'm using it underclocked from 1080MHz to 1030MHz, so it boots and does 3d stuff, but occasionaly crashes. Time to get a new one.
I was looking at 3 models, GTX960, GTX970, and R9 380x.
In my country, I can get the Gigabyte G1 models for 210, 310 and 235EUR respectively.
I can wait for the new cards to pop out but I doubt they will be cheaper. I was to go for 960 because the image on NVIDIA seems a bit better in my oppinion, but I think the 960 can't handle 60FPS in some games. 970 was the next choice, but it's a 100EUR more which I'm thinking to invest in a newer CPU (Currently it's a FX8320 OC'd to 4.3GHz, used to be 4.8GHz before Sabertooth died).
Any suggestions? Anyone owned a GTX960 and a R9 380X maybe? I'd like to know if it's just my sight or NVidia really has better imagery.
Thanks guys!
New to OCN?
if you can wait for AMD Polaris it would be a good choice, and if then decide if you cant then get a cheap r9 290 /290x
Hey,
Here in Serbia I can't find new 290s, only 300 series are on stock. Even in nearby countries it's impossible to get ones that aren't used, and I prefer to buy new hardware.
Any other options?
1 - 4 of 4 Posts
