What a tremendous undertaking! Do you plan on building your own chassis for this monstrosity?
Originally Posted by RockNRolla ![]() I am beginning to both buy and mod parts for my dream build and seeing as how no standard ATX power supply will give me the stability I desire, I have decided to go with not one, but two PC Power & Cooling Turbo Cool 1200W ESA PSUs. One will power the motherboard, processor, hard drives etc., while the other will power two NVIDIA GeForce GTX 395s and an NVIDIA GeForce GTX 360. I have started removing wires from the first PSU, leaving only enough for six 6 pin and two 8 pin PCI-E connectors.Once I finish the diagram of what terminals are hot and which are ground I will remove all of them and very neatly solder an even higher gauge wire to them, build a custom housing complete with EMI shielding, EMI absorbing material, and modular connectors. ![]() EMI Shielding Shield Absorber Connectors: Male Female |
Originally Posted by RockNRolla ![]() How can I put a dummy load on them? Solder in some resistors? Actually, the voltage adjustment is right on the side, can I disable the 3.3 and 5v rails? |
Originally Posted by RockNRolla ![]() Okay, I figured it out. I will use a 1 AMP resistor on the +3 and +5v rails to simulate a load. |
