1 - 1 of 1 Posts
Custom 80/20 case build constructed with 1" x 1" and 1" x 2" T-slot aluminum.
My first custom case build.
Dimensions will be 36" x 24" x 50"
Base.
https://www.dropbox.com/s/2hdt92p5n2rxcog/2015-01-10%2020.54.33.jpg?dl=0
Bottom of base with caster plates on.
https://www.dropbox.com/s/qq6q8coo99d1xz1/2015-01-10%2020.54.45.jpg?dl=0
Base with Radiator platform installed.
https://www.dropbox.com/s/ie8k6qhzhqzpcfl/2015-01-10%2021.13.03.jpg?dl=0
Two MORA-360 radiator covers installed and secured in the frame work.
https://www.dropbox.com/s/wjq5a8qk9p7wu86/2015-01-12%2019.02.16.jpg?dl=0
Mock up with two MORA-360's.
https://www.dropbox.com/s/0w6id3j7v0jai0k/2015-01-12%2022.25.37.jpg?dl=0
working on right side of chamber number one / bottom of chamber number two.
https://www.dropbox.com/s/y6nkhz3jelrv6yx/2015-01-12%2022.25.47.jpg?dl=0
Right side of case.
https://www.dropbox.com/s/ojswim64u94pvla/2015-01-12%2022.25.53.jpg?dl=0
Working on front.
https://www.dropbox.com/s/lhyaif5gt94qx1r/2015-01-13%2018.46.32.jpg?dl=0
Mounts put on radiators.
https://www.dropbox.com/s/4nwmycodeqd4qp7/2015-01-13%2018.46.46.jpg?dl=0
https://www.dropbox.com/s/lgiytgw9b99vy28/2015-01-13%2018.46.41.jpg?dl=0
Bottom of chamber three.
https://www.dropbox.com/s/408qvycxj3d8w9m/2015-01-13%2020.05.02.jpg?dl=0
Top finished.
https://www.dropbox.com/s/793vvons02dcfh5/2015-01-13%2020.33.27.jpg?dl=0
https://www.dropbox.com/s/31n56kai0j692yb/2015-01-13%2020.33.38.jpg?dl=0
View from rear of case.
https://www.dropbox.com/s/1oi6bexcduo1opx/2015-01-13%2020.33.50.jpg?dl=0
Rear of case and right side view.
https://www.dropbox.com/s/0wo6pe6rvxzyjds/2015-01-13%2020.34.02.jpg?dl=0
Right side.
https://www.dropbox.com/s/ct55y6gu2bzo152/2015-01-13%2020.34.23.jpg?dl=0
https://www.dropbox.com/s/lhe9sdgzug8351z/2015-01-13%2020.40.14.jpg?dl=0
1 - 1 of 1 Posts
