Custom Cable Router
743 Views 11 Replies 6 Participants Last post by  blupupher
Is there a PCI card you can get to accept the coaxial cable input?
1 - 12 of 12 Posts
Nothing that I know of will accept a coaxial cable directly into your computer for internet. You need a router for internet anyways, so why not use ethernet?
You mean a "custom cable modem".
You need to ensure OS support.
Zoom CableModem 5001
you can get a pci card based docsis cable modem... but you don't want one, as most ground loop issues arise from the cable network... this is why your standard external cable modems aren't grounded and don't come with a shielded patch cable, you want that isolation.
I'm pretty sure that any Zoom PCI cable modems you find will be ancient Docsis 1.0. The Zoom 5011 is almost a decade old now... Chances are your cable provider is Docsis 2.0...
Ethernet is a wonderful standard, and honestly, you don't want a direct internet connection to anything but a hardware firewall/router.
I have a cable modem downstairs and a Netgear router that has both ethernet AND coaxial inputs from the modem. Then I plug directly into the router. Your saying I don't need the coaxial were I to build a custom router?
A modem connects your local network to the Internet. A router directs data within your local network and to the modem. They perform two different tasks.
Can you build a modem?
Sure... but why?
Why not? I would assume a custom modem would be better than the one Comcast gives you.
A Linksys or Motorolla Modem is ~ $60, probably better than anything you could build and cheaper, and the fact that I doubt any cable company would activate it.
1 - 12 of 12 Posts
