Custom case!
778 Views 9 Replies 9 Participants Last post by  Thumper
I've decided that I am tired of the old Ho-hum case, and am going to (somehow) make my computer case out of!
*DRUMROLL*
A MICROWAVE!
Yes ladies, and gentlemen, I am going to put all of my computer parts into a microwave, and then post the pictures when I am done!
1 - 10 of 10 Posts
just dont turn the microwave on after ur done
lol
be careful - microwaves are like monitors...they store thousands of volts months and months after theyre off
To late hes been electricuted already
j/k
Anyhow arent microwaves fairly small to begin with?
Yeah, even though it's not too original, and it's kind of dangerous, I still want to do it, because it's a microwave... haha
Plus, I think it will be an interesting project to try out, sure the consequences can be pretty bad, but if it all works good, it'll be amazing. I plan on cutting holes in the side, and putting clear side pannels in there, and having the PC being water cooled, with neon greed liquid.
I say keep the micro wave stock and intergrate a comp into it.. ground breaking! heat up coco while unleashing hell with your deagle. downside is... plugging in and most definately turning the microwave on while your components are in close proximity will mean certain catostrophic malfunctioning
build it, then take it to work and hook it all up and say "hey guys.... check the new AMD microwave, it comes with windows!"
Lame....lol.
go for it man, microwave computer case mod = not a bad idea
1 - 10 of 10 Posts
