81 - 90 of 90 Posts
Knowledge is Success
Discussion Starter · #81 ·
Rig Advisor
Discussion Starter · #83 ·
Rig Advisor
So got the Flow indicator.
I haven't installed it yet because first i need to ask you something.
Which Flow diameter conversion should i use and it says to choose left or right but at the same time it says only used in water inlet, kinda confused
That thing is useless. You'll know you have flow when you can see the water move in the reservoir. What you need is a flow METER. That will measure the flow rate which is important. This indicates you have flow.
Rig Advisor
I already tried bro, he went with this and it's his choice.
I feel really uncomfortable giving you an answer on this one as I don't know any specific formula to change RPM to exact flow and every pump/meter is different. I will tell you that on that Bykski meter I listed (Which is in my office rig) usually sits around 106 RPM = 4.6 L/m. Just how accurate that meter is.... well that's debatable, but it's pretty close.
Discussion Starter · #87 ·
Well, things did not go as planned.
The motherboard didn't detect the flow indicator Rpm speed ( N/A ) then little wheel in the Flow indicator wont spin when my pump is at 2500Rpm, it starts at 3500Rpm
I assume that with the pump at 2500 there is not much Flow rate but curious is that my GPU-CPU and Water temps are great, i ran 2 test, one with the pump at 2500Rpm and the second at 3500RPM, each test using Prime95 for 30 minutes.
2500RPM
2486894
3500RPM
2486895
The water temps was 28c max on both test.
Rig Advisor
2500RPM
3500RPM
Honestly very hard to troubleshoot the issue. I do know that those RPM meters sometimes take a bit to spin freely (They are stiff). I would be very happy with those tests man. I don't think there is anything else you should be doing. Unless you are just a tinkerer like myself, there isn't anything from a thermal standpoint I would be trying to troubleshoot. Just my 2c
Discussion Starter · #89 ·
I will remove the Flow indicator and will return it, the seller Will charge me €5 because he needs to Clean it and sell it as.
2486905
Reactions: Avacado
Discussion Starter · #90 ·
81 - 90 of 90 Posts
